problem with lowered car
Old Dec 15, 2006 | 05:42 PM
tampabitches's Avatar
TR Balla Donor Supreme
Default problem with lowered car
I just lowered my car and i noticed that my passenger side front wheel sits to far back and the driver side sits in the middle. Didint notice it when the car was stock height. What could be causing this?????
91 CIVIC SEDAN LX TRADED
91 CIVIC HATCH B16A DX TRADED
97 CHEVY S10 ON BAGGES TRADED
98 CIVIC COUPE HX TRADED
91 CIVIC SEDAN EX TRADED
91 ACURA INTEGRA LS SOLD
91 CIVIC HATCH DX TRADED
93 FORD 150 XLT GOT STOLEN
92 ACURA INTEGRA LS TRADED
97 CHEVY 1500 350 TRADED
87 MAZDA B2000 TRADED
92 CIVIC SEDAN LX TRADED
92 CB7 LX SOLD
96 CHEVY S10 SOLD
92 FORD EXPLORER 4X4 TRADED
96 FORD F150 XLT TRADED
93 ACURA INTEGRA TRADED
95 FORD RANGER 4.0 TRADED
95 CHEVY S10 4X4 SOLD
Old Dec 15, 2006 | 05:59 PM
hondachris1994's Avatar
hatchback1994
U need a camber kit so u can adjust them rt
Old Dec 15, 2006 | 06:03 PM
the wheel is cambered but i cant figure out why the wheel sits so far back. Like i have somthing bent on the suspension
92 CB7 LX SOLD
96 CHEVY S10 SOLD
Old Dec 15, 2006 | 06:05 PM
hatchback1994
U have no camber adjustment on your car unless u installed 1
Old Dec 15, 2006 | 07:38 PM
Derka's Avatar
[Club DSM] What is caster?
If the tire is sitting too far back that isnt an issue with camber. Im pretty sure that is a caster issue... it probly just needs an alignment
1998 crv daily beater
Old Dec 15, 2006 | 09:57 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
what kind of camber kit?
i have the skunk2 upper front control arms, and on both sides the bushing where the A-arm mount to the two pins where the mount bolts it tore out, so the arm literally moved back and forth on the pins, made some clunking noises occasionally... might want to check that...
Old Dec 16, 2006 | 05:38 PM
na200whp's Avatar
Powered by BOOST
Look at the strut rods. The rubber bushings are broken or the bolt is loose. If you jack up the side of the car the tire is sitting back on and see if the tire moves forward and backward you will find the problem.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Dec 16, 2006 | 09:10 PM
#1cb7's Avatar
the bushings are good and everything is tight
JDM = Jackin' Dude's Money
Old Dec 17, 2006 | 03:01 AM
I'm finally getting caught up again by Sunday afternoon,
17 Dec, if you want someone to look at it.-no charge.
Sounds like you do your own work. True?-Bob
Old Dec 17, 2006 | 08:55 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
def check ur bushings.....and sounds like a combo of caster and camber probs...no factory adjuestments to either unless installed....invest in a good front crossmember with caster adjustments...i did saved my ass from eating tires, wheel hop, eating tires, and that nasty EF pull under hard acceleration..
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
