What does this mean? *pics*
Old Dec 14, 2006 | 01:44 PM
  #21 (permalink)
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
i got u tim..see u in a little bit with that ls head......
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Dec 14, 2006 | 02:02 PM
  #22 (permalink)
skunk2racing97's Avatar
UF Mech/Aero Eng
eluzzionz - yea dude, def my first thought
unfortunately, with Xmas time approaching, its not gonna happen
mike - i got one word man for you, and its CLUTCH.
Old Dec 14, 2006 | 03:19 PM
  #23 (permalink)
KJ's Avatar
KJ
bored at work
You might not even need rings.
Old Dec 14, 2006 | 04:02 PM
  #24 (permalink)
UF Mech/Aero Eng
haha i know, i realized that a little too late tho...
i was actually gapping the new ones when i remembered what you said, grabbed some gas, and started kicking myself...
anyway, this thing is gonna be a champ once its fixed *fingers crossed*
thanks again kevin
Old Dec 14, 2006 | 04:22 PM
  #25 (permalink)
Cold_Beer's Avatar
Rockin' 4 more Cylinders
if you need a head homie, LMK i got you.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Dec 14, 2006 | 06:27 PM
  #26 (permalink)
UF Mech/Aero Eng
thanks bro, i appreciate the offer.
ive already used what kevin said on three and saved myself the hassle of buying busted ones, just got back with one from bradenton, and going to go check it/throw it on.
will update tonite.
Old Dec 14, 2006 | 07:11 PM
  #27 (permalink)
TurboJdmEk's Avatar
is on blocks...
g/l homie hope you getter running strong
its coming...
Old Dec 15, 2006 | 12:52 PM
  #28 (permalink)
UF Mech/Aero Eng
thanks for the bump bro...
so i assembled the bottom end, new standard bore rings, used the new headgasket i had the first time, and the new head....
so i crank it up last night, and im not getting anything. wont run at all. i check the compression in #1 and get 30 fucking PSI. i get a heinekin and go to sleep.
get up this morning, go check all the compression again, and i got #1-4: 190, 185, 170, 150.
so everything is better, on the whole, but i still have this weird decrease...
any ideas? it will run and idle fine now, i just dont want to drive it around knowing the numbers are that different.
oh, and the head i got last night from mike got the Kevin-gas-test-special, and passed with flying colors.
Old Dec 15, 2006 | 05:43 PM
  #29 (permalink)
KJ's Avatar
KJ
bored at work
Did you disable the injectors. A fresh motor might give weird numbers if the injectors are squirting and washing the walls of the oil. Drive it a bit and see if the rings seal a little better. Also how did you prep the cyliner walls?
Old Dec 15, 2006 | 06:07 PM
  #30 (permalink)
UF Mech/Aero Eng
i had the injectors clips unplugged while i was checking compression, but i did have em on when i tried to run it at first, so that may have affected it...
i will go drive it around a bit and see what happens.
cylinder walls got a light hone from a 3-stone hone on a drill with some cutting oil, the same way ive prepped all my engines....
