What does this mean? *pics*
Old Dec 14, 2006 | 07:18 AM
CubanYoshi's Avatar
You can't handle it
To tell you the truth, even with my amount of knowledge in the Honda area (which has been that long, only about 3 years), I could almost tell you that there is almost no way that your exhaust is causing your car to run like shit.. I have seen it restrict like hell, but I cant see your exhaust keeping your compression numbers down like that. Like KJ said, after you re-ring it you will pretty much know whats up.
THE CIVIC 2004-2009
Old Dec 14, 2006 | 07:24 AM
KJ's Avatar
KJ
bored at work
While the head is off check how your valves are sealing. An easy way to do it is to stand it on its side so the ports are facing up and fill the ports with gasoline and watch to see how fast it runs past the closed valves. It is a good way to check to see if any valves are slightly bent or in need of a fresh valve job.
Old Dec 14, 2006 | 07:25 AM
hondamike504's Avatar
HONDAMIKE.COM
Originally Posted by skunk2racing97
i know, the standard for an LS is 199, with a factory specified minimum of 140 and a deviation of 28, but i would never want to run a motor with 28 PSI difference...
anyway, i got the motor from a kid on here, who said he worked at a machine shop, told me it was completely rebuilt, and seemed credible (i'd done business with him before). its been idling bad since i got it, and the freakin IM gasket was a gasket-makered used one, so the kid is obvously full of shit.
needless to say, i will never run a motor i didnt build myself again
thanks again for the help.
I love T.R. ,sorry about your motor.Good luck w/ the re-build.
"THE REAL HONDAMIKE" ASE Master Technician
"Imitation is the highest form of flattery", but clones can get it wrong because we are promoting individuality and being proud of yourself.
Old Dec 14, 2006 | 07:28 AM
need4speed's Avatar
id def. re-ring and then run it again
Old Dec 14, 2006 | 07:57 AM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
exactly what he said...i just got done with a 95 ls doing almost the exact same thing...ended up couple of the intake valves were bent..and while i was at it new stem seals and valve job....and a rering wouldnt be a bad idea also.....hows the piston to wall clearance? any excessive piston movement...g/l with this..
mike
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Dec 14, 2006 | 09:16 AM
skunk2racing97's Avatar
UF Mech/Aero Eng
cubanyoshi - i wasnt saying the exhaust is making it run crappy, i know thats not it, but ive heard people say before that an excessively restrictive exhaust can cause a HG to blow, and i didnt know how true it was. at that point, i was so lost i was trying to find any possible explanation.
kevin - good tip, and i will try it as soon as i finish gapping the new rings
hondamike - yea, there are def some sheisty bitches on here... it sucks for those who know what they are doing and try to sell legitimate parts.
mike - im gonna try the valve check, and as for piston/wall clearance, they feel pretty snug, but im gonna check it once the ring gap is done.
thanks for all your help guys, hopefully i can drop these pistons in and show some serious compression numbers....
Old Dec 14, 2006 | 11:40 AM
  #17 (permalink)
UF Mech/Aero Eng
UPDATE:
tried what kevin suggested, and found MAJOR leaks, cept not through the valves. the valves seem to be fine... its leakin out through the coolant passages in the head, meaning i have cracks in the head around the top of the combustion chambers...
at least that explains why i was burning coolant. never overheated tho, which is weird.
new LS head time.
Old Dec 14, 2006 | 12:55 PM
  #18 (permalink)
clean teg's Avatar
wow sorry to hear after all that
Old Dec 14, 2006 | 01:12 PM
  #19 (permalink)
UF Mech/Aero Eng
yea, kinda sucks...
oh well, least i know itll be fine once i get a new head on it.
i would have at least thought i would hear air coming out when i did the compression check... some of these leaks were crazy...
Old Dec 14, 2006 | 01:43 PM
  #20 (permalink)
Eluzzionz's Avatar
vtec head time?...hehe..glad u found the problem..good luck findin another good head...maybe take some gasoline with u to test the new one..
