VAFC questions.........
Old Nov 5, 2006 | 05:25 PM
SLEEPIN_92SE-R's Avatar
Default VAFC questions.........
well first off putting a vafc on a S2000 would work fine and get improvement or not due to the setup they are running.......then second is there a big difference on the vafc1 and the vafc 2....... thanks
Old Nov 5, 2006 | 06:17 PM
mtber's Avatar
A vafc will only improve the vehicle if the factory ecu's tune is preventing the vehicle from making all the power that it can.
A vafc will only make an improvment if it is used to tune the vehicle using a dyno and wideband oxygen sensor.
The difference between the vafc I and vafc II is simply features, check out apexi-usa.com
There are much better solutions for an s2000 such as aem ems or hondata's 2006 s2000 ecu reflash.
Old Nov 6, 2006 | 05:20 AM
so wat your saying is that for my boys s2000 its better off to get the ecu chipped and tuned on the dyno than to waste time installing a vafc.......
Old Nov 6, 2006 | 05:22 AM
wat is he looking at spending if i took it to you (phearable.net) and we tuned it a little thanks
Old Nov 6, 2006 | 07:54 AM
mtber's Avatar
You can't "chip" the s2000 ecu and tune the car.
Your options are (depending on year): A standalone such as aem ems
or a reflash offered by a company that does obd2 reflashes, the last option would be a piggy back such as a vafc.
Thanks,
John Vega - Phearable.net
Old Nov 6, 2006 | 09:03 AM
so how much you charge to install the vafc.... 2002 s2000-mods:intake, exhaust after cat, fuel pressure regulator(not installed), VAFC1 (not installed).......now its a little more clear how much and wat are the options with what he got installed thanks
Old Nov 6, 2006 | 10:53 AM
mtber's Avatar
Please consult the tuner directory on and contact a tuner directly via email/pm or phone.
https://www.tamparacing.com/forums/h...directory.html
