skunk2 stage 2 for turbo cams
Old Oct 31, 2006 | 07:41 AM
hybridlsvtec's Avatar
Default skunk2 stage 2 for turbo cams
i know probaly a stupid question but can skunk2 stage 2 all motor cams be used for turbo cams?
Old Oct 31, 2006 | 07:49 AM
95gainfla's Avatar
smokes weed...everyday.
of course, you just wont benefit from the lift/duration specs as much as you would if you were N/A...since thats what it was made for.
I <3 RooR!!!!!!
Old Oct 31, 2006 | 09:10 AM
alright thanks, just wanted to know cuz i know where to get some cheap and didn't want to spend the money for a set of knew ones. would they be better then ctr's or am i just wastin my time in puttin them in? and i need a good dyno guy to tune aem, any suggestions there?
Old Oct 31, 2006 | 09:12 AM
Eluzzionz's Avatar
if u get them for cheap try to trade/sell for turbo..or if u just are in need of a pair of cams cheap..use gsr..they are best oem for turbo..
Old Oct 31, 2006 | 09:32 AM
KJ's Avatar
KJ
bored at work
Not a good set of turbo cams unless you are running a large turbo and an equal length manifold. I wouldn't run those cams unless I was pushing a gt40R or bigger. If you are running a log or cast manifold the biggest cams you'd want would be itr's and even then I'd choose gsr's. Most turbo cams on the market won't work better than itr's.
Old Oct 31, 2006 | 09:43 AM
ok cuz i am runnin gsr's, on a ram style tubular manifold with a t4 t67 on a lsvtec 84.5 set up, just wasn't sure about them, was just wondering if they would help spool up a lil bit better.
Old Oct 31, 2006 | 12:32 PM
KJ's Avatar
KJ
bored at work
That setup will actually probably work out ok with the stage 2's, won't help spool at all but should be a good top end cam setup with the right settings. What AR on the turbine is your t67?
Old Oct 31, 2006 | 12:41 PM
the turbine side is a .84
