h22a question
Old Oct 8, 2006 | 07:58 PM
95hbsi's Avatar
Default h22a question
what axles do I use if I swap an H22A into an EG?
Old Oct 8, 2006 | 09:06 PM
PooN_Lude's Avatar
Hasport h22 stage 1 axels get a thumbs up from me, I've also heard good things about gator axels, im pretty sure they're swap specific as well.
Old Oct 9, 2006 | 01:32 AM
Rob's Avatar
Rob
Yeah, Gators are nice. It will be H22 axles (assuming of course you are swaping both the engine and tranny. I hope you are.)
Twice the man you are! Unless you are 11'6", in which case we are the same ammount of man.
Originally Posted by moldyhands
this is why god invented abortions
Old Oct 9, 2006 | 09:47 AM
Deuche's Avatar
- Right 90-93 Integra Axle - You must use a prelude/accord inner CV joint in order for the axle to lock into the transmission. The inner spline shaft is slightly longer for the prelude/accord than the integra. A 90-93 Integra shaft and outer CV will work with the prelude inner.
Here is a picture explaining why:
- Left Custom 92 Prelude Inner CV joint with 90-93 shaft & Outer CV joint from
Raxles for $170 1-800-257-8192
OR
- 1990 Manual Accord Intermediate Shaft
- Left and Right 90-93 Integra Axles (with prelude inner cv joint on the right axle)
OR
- Driveshaftshop.com Stage/Level 1 axles Right & Left side using prelude intermediate shaft I personally recommend using HASport custom axles for ease of installation.
Old Oct 10, 2006 | 02:27 PM
Blue92ludesi's Avatar
the 90-93s are sometimes a little too long, and bind, try the 90-93s with the accord shaft, if they work for you then your golden, if you get binding, then try the 86-89 shafts, their 1 inch or so shorter.
If you have the Prelude midshaft, then use the 86-89 teg shaft with a prelude inside to make it for the prelude mid shaft.
im using a B16 axle right now to go into my prelude midshaft, but its a bit too long, i get binding when i take a turn fast.
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
