Valve clearance question
Old Oct 5, 2006 | 05:09 PM
95gsr-vtec's Avatar
Default Valve clearance question
im just wondering if i will have any clearance problems with this setup, gsr block w/ ctr pistons, skunk2 stage 2 cams, and 1mm oversized valves, the head has only been resurfaced, im just worried about the oversized valves tapping the pistons
Old Oct 5, 2006 | 06:05 PM
96ek's Avatar
The only way to know for sure is to clay the block.dont quote me but i think you might have a clearance issue.
Old Oct 5, 2006 | 08:07 PM
mtber's Avatar
You should be ok as long as you dont get crazy with cam timing.
Old Oct 5, 2006 | 08:20 PM
mtber's Avatar
+1
Old Oct 6, 2006 | 12:51 AM
95gsr-vtec's Avatar
how about with stage 1's
Old Oct 6, 2006 | 03:33 AM
KJ's Avatar
KJ
bored at work
Stage 1's you will be fine. You will also need to check valve to valve clearance with those cams (stage 2) and oversized valves.
Old Oct 6, 2006 | 06:59 AM
BERT-O's Avatar
yO!
ugh....one mis-shift and BOOM!
Honesty, I wouldn't go w/ the Sk2 stg 2, stick w/ Pro 1s with zero setting and download the map for it on Chrome.
actually, oversized valve??? how much is the head milled???
Old Oct 6, 2006 | 09:20 AM
95gsr-vtec's Avatar
the head has only been resurfaced once, so its not milled very much
