need help quick with integra ls
Old Sep 23, 2006 | 02:17 AM
stackzond3ck's Avatar
Default need help quick with integra ls
just helping a friend put on some stage one cams and the car won't crank timing was set right TDC spark plugs are ok no foul at all oil pumps out the head and you can smell the gas, it has spark but won't fire up what do you think is the problem
Old Sep 23, 2006 | 07:14 AM
TurboChickCominThru's Avatar
Good talk!!!
Check your fuses for the fun of it ha ha. But really if you took off your dizzy when you did the cams if the rotor on the dizzy got spun upside you are now an incorrect firing order. Take the dizzy off turn it 180 degrees and put it back on. YOu can also go to a part store and get a spark plug wire tester to check how strong the spark is. Good luck
Old Sep 23, 2006 | 10:29 AM
thankz man i'll try that todai i hope it does work
Old Sep 23, 2006 | 03:55 PM
Good talk!!!
Welcome, hope it works
Old Sep 23, 2006 | 03:58 PM
EGKID's Avatar
did you adjust the valves to the right clearances
Ricky
