Fluidyne Fans
Old Sep 2, 2006 | 01:55 PM
Topher's Avatar
DVDA
Default Fluidyne Fans
Does anyone know if the fluidyne radiator for (00 gsr) will accept both stock fans? On some websites it says yes and others no. If it only accept one fan does that cause any cooling issues? Thanks -chris
Old Sep 2, 2006 | 02:12 PM
mtber's Avatar
I do not believe the condensor fan will clear your header if you have one.
If you are running the factory exhaust manifold, you may get lucky.
I recommend you buy the flexalite integra fan kit if you want to save some money on the fans.
Old Sep 3, 2006 | 08:15 AM
Topher's Avatar
DVDA
Thanks !
Old Sep 3, 2006 | 02:34 PM
nolexforever's Avatar
mtber is right, with the fluidyne radiator it requires a slimmer AC fan to clear the header..Fluidyne also sells a slimmer fan obviously.
Old Sep 3, 2006 | 03:27 PM
opiumdaze's Avatar
+1... the fan on the left you can still retain
Old Sep 3, 2006 | 04:10 PM
BG-33P_Hatch's Avatar
Back in the Game
+1 to that also.....Good luck with it
Old Sep 7, 2006 | 06:55 AM
Topher's Avatar
DVDA
thanks
