H22 swap into 92 prelude
Old Aug 6, 2006 | 03:46 PM
Derka's Avatar
TR Balla Donor Supreme
Default H22 swap into 92 prelude
Im taking out the h23 and dropping the h22. I did some searching on honda-tech, but couldnt find any real info. I know i need the h23 dizzy, and i need to wire vtec. Is there anything else im forgetting? Both engines are obd1 so that isnt a problem. Does anyone have wiring pin outs for a prelude?
Thanks
Derek
1998 crv daily beater
Old Aug 6, 2006 | 09:37 PM
Derka's Avatar
one time
Old Aug 7, 2006 | 05:35 AM
Blue92ludesi's Avatar
call me and ill help ya out
813-943-4117
all 93+ Ludes are prewired for vtec, some 92 SIs were prewired too, just not the S's
Check yer ecu pins and see if the vtec wires are allrdy in the harness. in which case all u have to do is run the wires to the shock tower plug under the hood. And as long as the h22 you got has a External coil the dizzy will plug right up.
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
Old Aug 7, 2006 | 06:06 AM
Derka's Avatar
813-943-4117
Ok thanks man, i will call for info on the wiring. But im just going to use the
h23 coil with external coil. Rep for you
Old Aug 13, 2006 | 01:58 PM
jdmgirl03's Avatar
i dr0p biitchez panties:]
is this the prelude you were teliing me about the other morning?
Myspace
