accord cel codes
Old Jul 21, 2006 | 06:59 PM
magic carpet's Avatar
Default accord cel codes
my friend has a 90 accord. throwin a few CEL codes.......there is a 6, 1 and theres another with 3 long blinks and three short ones.....anyone know where i can found out what the codes are?
Old Jul 22, 2006 | 06:31 AM
n e one have a website with these codes or anything?
Old Jul 22, 2006 | 07:40 AM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
look in the FAQ i have a list of all the codes. All honda codes are the same.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Jul 22, 2006 | 07:41 AM
Cold_Beer's Avatar
ah hell here we go.
Originally Posted by Cold_Burr_FTW
Cleaned it up a lil, just to get rid of some chit chat.....and
Trouble codes FTW
dOxygen Sensor "A" (Primary)
Oxygen Sensor "B"
MAP Sensor (Manifold Absolute Pressure)
4
CKP Sensor (Crankshaft Position Sensor)
5
mechanical problem / disconnected piping
6
ECT Sensor (Engine Coolant Temperature)
7
TP Sensor (Throttle Position)
8
TDC Sensor (Top Dead Center)
9*
CYP Sensor (Cylinder)
10
IAT Sensor (Intake Air Temperature)
12
EGR Lift Sensor (Exhaust Gas Recirculation)
13
BARO Sensor (Atmospheric Pressure)
14
IAC Valve (Idle Air Control)
15
Ignition Output Signal
16
Fuel Injector System
17
VSS (Vehicle Speed Sensor)
r
19
Automatic Transmission Lock Up Control Solenoid Valve
20
Electrical Load Detector
21*
VTEC Solenoid Valve
22*
VTEC Oil Pressure Switch
23
KS (Knock Sensor)
30
Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
31
Automatic Transmission Signal "B"
41
Primary Oxygen Sensor - Heater
43
Fuel Supply System
45
System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48
LAF Sensor (Lean Air Fuel)
54
CKF Sensor (Crankshaft Speed Fluctuation)
58
TDC Sensor 2 (Top Dead Center)
61
Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63
Oxygen Sensor, Heated - Sensor 2 (Secondary)
65
Oxygen Sensor Heater (Secondary)
67
Catalyst system Efficiency Below Threshold
70
71
Cylinder 1 Misfire or a Random Misfire
72
Cylinder 2 Misfire or a Random Misfire
73
Cylinder 3 Misfire or a Random Misfire
74
Cylinder 4 Misfire or a Random Misfire
75
Cylinder 5 Misfire or a Random Misfire
76
Cylinder 6 Misfire or a Random Misfire
80
86
90
Evaporative Emission Control System
leak detected in the fuel tank area
91
Fuel Tank Pressure Sensor
low input
92
_Jake D
Old Jul 22, 2006 | 10:18 AM
Cold Burr FTW
thank you sir
