What else could it be?
Old Jul 21, 2006 | 04:38 PM
94DOHCDELSOL's Avatar
TR Balla Donor Supreme
Default What else could it be?
I replaced the Throttle body on my car, as well as got a new TPS and MAP sensor. Now, when I turn the car on, it idles at about .3, not 3, .3 . What could this be?!
Old Jul 21, 2006 | 05:10 PM
DemonCivic's Avatar
did you make sure not to switch the plugs around?
Old Jul 21, 2006 | 05:28 PM
yes, I've tried it both ways
Old Jul 22, 2006 | 04:35 AM
any other suggestions?
Old Jul 22, 2006 | 04:40 AM
Ef9Hatch90's Avatar
Cant you adjust the idle by a screw on the side? My experience if the wires were backwards your idle wouldnt be jacked up, but upon flooring the vehicle you would bog out...
Old Jul 22, 2006 | 04:41 AM
DemonCivic's Avatar
do you have a check engine light? it has to be electrical or vacuum, since that is all you messed with. double check everything and make sure your TPS is installed correctly. g/l
