Help on a door panel
Old Jun 18, 2006 | 10:38 AM
n0re's Avatar
Default Help on a door panel
SOme how im always having an issue with the tracktion (wndow)on my honda door last night it got out of place once again and i fixed it but i cant seem to put back the door panel...its actually pissing me of any one knoe if theres a certain way to put it back in .....yes yes i knoe stupid question but hey im Focking aggrivated with this shit...
Old Jun 19, 2006 | 04:00 PM
Aren't there some pins that push into holes in the door frame?
Has this car been hit? What does it need to fix it for good?
If this has happened more than once, do you remember how it went back together last time? If you want some quick release fasteners put on that door, so you can fix it
easier/faster next time, pm me -Bob
Old Jun 20, 2006 | 04:53 PM
TSX24L's Avatar
power windows, there usually known for the window regulator and the window regulator from the up and down movement somtimes bends the run channel. Usually you can get away with bending the run channel back into place or as best as you can get it and recheck your window. Adjusting the glass could also be your problem Usually you just loosen the bolts that hold the window on and push up and back (towards the back of the door) and then tighten the bolts. (10mm)
This is usually if your window keeps going off track. Problable cause if your run channel is bent. Why its bent, could be alot of reasons. Regulator could be the cause.
Tacktion are you refering to the plastic glued to the door frame? If your cars old like mine there more then likely going to have to be replaced because they get hard and brittle and scrape off all the old glue with a razor blade and adesive remover and a rag. I don't know what your talking about though. Just make sure all your tabs are in place. There are sometimes hidden ones under the door handle that you don't see and come out when you pull the door panel off. When you put the door panel on they don't go in properly and won't cause the door panel to go on right. Check were its poping out.
