soft clutch
Old Jun 13, 2006 | 03:29 PM
Lookin2GoFA$T's Avatar
Team 'Petersburg Puller
Default soft clutch
today my clutch pedal went almost to the floor in my 98 ls and then caught the gear immediately after rising. i searched and checked the fluid level in the clutch resevior, it was dry. can i just add the brake fluid? do i need to bleed the system? how do i do that? Thanks for any help
Old Jun 13, 2006 | 03:55 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
brake fluid , clutch fluid= same shit..
add some and i recommend bleeding the clutch.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Jun 13, 2006 | 07:14 PM
thanks for the help. i know about the dot3, and i added some and tried to bleed the line, but the screw valve is stuck, so i put some free-up on it and will do it up in the am. thanks again.
Old Jun 13, 2006 | 10:47 PM
This might sound stupid, but be sure the bleed screw is turned in a counter clockwise direction to unscrew. It may need a sudden jolt to break it loose. Use a box end wrench
so you don't round off the bleeder.-Bob
Old Jun 14, 2006 | 07:50 AM
thanks bob, i was turning it in the right direction, but there was doubt in my mind.
