help asap, changing axle
Old Jun 3, 2006 | 11:31 AM
TIM TIM TIM's Avatar
could be worse
Default help asap, changing axle
i got EVERYTHING back together, but i do not have the right size socket for the bolt to go on the end of the axle, and also does it need to be torqued to a certain amount or just put on tight?
aim:because tim said
Old Jun 3, 2006 | 11:38 AM
slovvcrx's Avatar
my crx is 134 lb-ft and i think i used a 32 mm cant remeber
Old Jun 3, 2006 | 11:39 AM
indeed's Avatar
tranny breaker
32mm is correct.
Old Jun 3, 2006 | 11:41 AM
could be worse
96 teg adn crx the same? is it critical or can i just tighten it lol
Old Jun 3, 2006 | 11:43 AM
slovvcrx's Avatar
i wouldnt feel safe with out using a torque wrench but thats just me.Tighten the bitch as hard as you can lol
Old Jun 3, 2006 | 12:59 PM
DAMPACHI's Avatar
Paul @ LHT Performance
If you overtighten the nut it will somewhat compress the wheel bearing. Use a tourque wrench.
Old Jun 3, 2006 | 01:06 PM
nefesto's Avatar
Your Mother's Best Friend
They are 5 bucks at sears..this might sound stupid but how did you get the nut off??
Old Jun 3, 2006 | 01:08 PM
Obviousreasons's Avatar
Welcome to Candy Mountain
250 Ft Lbs. Is the correct torque
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Jun 3, 2006 | 01:54 PM
YBlegal's Avatar
Broke not Built
damn than im pretty close when i tighten one down....i weigh 240lbs and i put all my weight into it when i tighten my axel nuts....
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Jun 3, 2006 | 05:23 PM
could be worse
i got it off with an impact gun lol.. i figured i would ask size while i was sitting here although i could have figured it out. main thing was hte torque
