Valve Clearance
Old May 22, 2006 | 05:41 PM
SmokinS13SR20's Avatar
That ginger...
Default Valve Clearance
Alright if i use a D16 Block along with a D15B1 Connecting rods which are 134.00mm long compared to a D16's length of 137.00mm, i wouldn't have to worry so much about the valves hitting the pistons, correct?
-Joe
Old May 22, 2006 | 06:20 PM
DemonCivic's Avatar
should be plenty of clearance but
clay it to know for sure
Old May 22, 2006 | 07:54 PM
That ginger...
mhmm will do if i do just wanted to make sure i was thinking straight tonight
Old May 22, 2006 | 10:17 PM
+1 on the clay test.-Bob
Old May 23, 2006 | 08:16 AM
That ginger...
I was jsut asking to make sure it would minimize the threat.
Old May 23, 2006 | 08:20 AM
99B16Si's Avatar
what crank?
Old May 23, 2006 | 08:21 AM
99B16Si's Avatar
if nothing changes beside a shorter rod youll increase your piston to deck clearance thus lowering your compression substantially. Dont know how much off hand but 3mm less of a stroke will definitely make a difference
Old May 23, 2006 | 01:49 PM
rangcrx's Avatar
engine building &best
WOW!!!!nothing like letting the cyl walls take the combustion this motor wont last long..i remeber a stupid friend of mine used b16 rods in his gsr..oh man that was great 2weeks go by i get a call My cars smokeing like hell took it apart heheh he said he was raceing so im guessing changeing gears at 8K or so well cracked the cyl wall and just fucked up the head...but good luck with this
i love AUTOZONE
Old May 23, 2006 | 04:08 PM
That ginger...
I was just wondering i didnt think it would affect the liability of the motor blowing
Old May 23, 2006 | 04:15 PM
That ginger...
Yea, the comp ratio drops close to 2 points. Just wanted to know if i would have more room for valve clearance. I would, but i wouldnt do this set-up i was just asking tomake sure.
