Plz Help:rod/pistion/ Block Combo??????
Old May 9, 2006 | 04:29 AM
MazdaMX3Freak's Avatar
Vtack THIS!!!
Default Plz Help:rod/pistion/ Block Combo??????
yeah i am going to be doing a set up pretty soon and i wanted it know if anyone could tell me if it will work or not b/c im worried my stroke might be to high. And what head gasket should i use. plz plz help thanx.......
d15b2 spr je pistions 9:0:1 COMP 0.20 OVER
d16 eagle h beam rods
d16y7 block 0.20 OVER
d16y7 micro polished crank
d6a6 head
-2008.5 Mazdaspeed3 CWP
Old May 9, 2006 | 04:50 AM
rangcrx's Avatar
engine building &best
all the d16s have the same stroke
i love AUTOZONE
Old May 9, 2006 | 05:01 AM
Vtack THIS!!!
yes but will the d15 pistions work b/c of the 3.50mm diffrence in height of the pistion to the d16 rods...?
Old May 9, 2006 | 05:06 AM
rangcrx's Avatar
yes it is just like useing b16 pistons in a b18 thay are all foreged the same pin,and bore just different valve clearence but 91 im guessing thay are flat so you should be ok if you worry JUST only open 1 rod and install one piston in the block first and check
i love AUTOZONE
Old May 9, 2006 | 04:55 PM
vertigo_16201's Avatar
You mean cast the same right? They arent forged.
Old May 9, 2006 | 05:52 PM
rangcrx's Avatar
im sorry yes that was the correct term..thanks vertgo
i love AUTOZONE
