Need Help SMOKES ALOT!!!!
Old May 7, 2006 | 11:53 AM
TurboJdmEk's Avatar
is on blocks...
Exclamation Need Help SMOKES ALOT!!!!
i just put a new headgasket and intake mani and throttle body on my car its a 88/91 hatch with a gsr block and a b16a1 head but when i start the car it smokes alot but after a while it'll stop its thick white smoke i think im running lean but not sure tho also i put a b&m fpr on it and i dont know how to adjust it so if anyone could lmk what the problem could be it would be a great help let me know all the things it could be so i can just go down the list thanks alot guys, john
its coming...
Old May 8, 2006 | 05:18 AM
TurboJdmEk's Avatar
is on blocks...
ttt some one help
its coming...
Old May 8, 2006 | 06:24 AM
cLined*2's Avatar
IM BACK!
did you get the b&m guage to see what psi your running... so you can play with the new adjuster??
Your engine is not a muscle that gets stronger as you work it harder.
The harder you work the engine, the faster it deteriorates.
Old May 8, 2006 | 09:15 AM
TurboJdmEk's Avatar
is on blocks...
no i think im just going to pick one up from advance today i can just attatch it to my fuel filter and what psi should i be pushing on it thanks alot
its coming...
Old May 8, 2006 | 09:54 AM
cLined*2's Avatar
IM BACK!
As far as I know:
-LS = 31-36psi at idle
-GS-R = 39-46psi at idle
- 38psi is the stated fuel pressure on the B16A when it leaves the production line.
My setup is opposite of yours I have a B16 Block with a GSR Head
I "should" be running 43psi
*Remember its better to run a little rich then a little lean
Old May 8, 2006 | 11:18 AM
TurboJdmEk's Avatar
is on blocks...
ok thanks alot that will help me out a bunch rep 4 u
its coming...
Old May 8, 2006 | 07:28 PM
cLined*2's Avatar
IM BACK!
Thumbs up
No prob. man Good Luck!
