Need help with gas lines!!!
Old Apr 29, 2006 | 05:22 PM
95gainfla's Avatar
smokes weed...everyday.
Default Need help with gas lines!!!
Hey guys. Got the civic running, but its running crazy rich and idling at around 3,500rpms. I have a lame ass firewall mount adjustable fpr, and when using the feed line that it came with, it wont hold up to the pressure in the line, and it expands and gets all weak and such. I need to know WHAT psi to run it at, and WHAT hoses I need?
thanks
I <3 RooR!!!!!!
Old Apr 29, 2006 | 06:52 PM
integraman89's Avatar
lost u already???
well, what do you have done to the motor, you would need to set the psi according to what fuel pump and how much work you have done, and as far as the hoses go, you may need to get a hose that is incased with a wire mesh.
Old Apr 30, 2006 | 06:19 AM
DemonCivic's Avatar
what hose are you using? make sure it is MPI hose not cheese bag low pressure fuel line.
Old Apr 30, 2006 | 08:58 AM
95gainfla's Avatar
its whatever the fpr came with.
its a stockblock z6 turbo with 450's and a walbro 255, crome pro basemapped p28.
should i just say 'fuck the firewall fpr' and get a B&M fuel rail mount so i dont have to worry about the damn lines?
I <3 RooR!!!!!!
Old Apr 30, 2006 | 10:35 AM
DemonCivic's Avatar
thats what i would do. g/l
Old Apr 30, 2006 | 10:45 AM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
lemme know if you wanna sell the wall mount....wht brand is it?
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Apr 30, 2006 | 11:26 AM
95gainfla's Avatar
some cheap one from ebay. i figured it would get me by til i can order a aem or b/m, but i guess not
I <3 RooR!!!!!!
Old May 1, 2006 | 09:23 AM
ekhatchboy's Avatar
Redrocket part 2
get a b&m and if you have problems and not being able to turn down the fuel pressure let me know and i will get you a write up on how to fix this.
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Old May 1, 2006 | 01:33 PM
kender's Avatar
gadget man
I don't know that much about crome, but I have been told it is supposed to be alot like hondata. That said, I would check to see if you even need the adjustable fpr. If crome adjusts your injector pulse width like hondata then you need to stick with a 1:1 rising rate fpr....The stock Fpr. The ecu will adjust the pulse width to allow more fuel, so the adjustable fpr is not needed.
U.S.S.A Crew Member #001
