dizzy question
will a b16 dizzy work on a LS head
yup. as long as the obd clips match up. if not, you'll have to solder the matching clip to your car(or pull the plugs from the dizzy plug, and plug them in plug for your engine harness.
the bolt patter is differant...i know if you remove a "leg" you can use ls on b16 so i guess you can do it the other way too......but it will not bolt up perfect.
remove a leg?!
Originally Posted by Ef9Hatch90
remove a leg?!
