H22 In Eg Write Up???
Old Apr 13, 2006 | 05:59 PM
pimpingreen13's Avatar
Default H22 In Eg Write Up???
Does anybody know where i can get a write up for this motor? Im putting it in a eg as it says in the title and i have never done a swap before so i need a good write up. (including the parts you need) I should have everything already except axles. Not sure which ones to use im running a prelude halfshaft. Just let me know any help would be appreciated. thanks
Old Apr 13, 2006 | 06:38 PM
SmokinS13SR20's Avatar
That ginger...
Wow, this is a complicated swap for being your first. I would have some people with a greta amount of knowledge help you out. IMO $.02
Old Apr 13, 2006 | 07:48 PM
Yeah my friends helping me but hes only done b-series. Im trying to find a write up to help me out. i most of the parts so thats not an issue.
Old Apr 14, 2006 | 11:19 AM
PooN_Lude's Avatar
It's not too bad, im doing the swap right now as well, im going to be running hasports axles- , but other than that things your going to have to do..Merge the two engine harness's - h22 and d series, wire up the resistor box, wire for vtec if your isnt an ex/si or a 92..You'll also need to cut out where your old shifter was to make room for the prelude shifter/shifter assembly as well as trim your stock passenger mount. Other than that the swap is pretty straight forward, im sure im forgetting a couple of things but goodluck.you'll find everything you need here http://honda-tech.com/zerothread?id=650329
Old Apr 14, 2006 | 11:40 AM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
It's not hard at all as poonlude stated , the thread he posted tells you everything you need to know.... you dont really have to "merge" the harnesses though. It all depends on what dizzy you use and what motor it is. all that really needs to be done to the harness is extend the alternator wire , starter wire , Iacv and Iat wires. .....I would get a chipped ecu and chip out the KNock sensor egr and speed limiter. as well as do away w/ the EGR completely.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Apr 14, 2006 | 04:27 PM
jl8383's Avatar
You could also get some rc 310's or 370's if you plan to upgrade the motor later and get rid of the resistor box. Def get a chipped Ecu though!!!
Old Apr 18, 2006 | 08:28 PM
yeah my boy let me borrow a p28 and p72 both are chipped but i will probably get a custom chip done untill i get it tuned.
