Where Can I Get A Good Write Up On Swaps???
Old Apr 7, 2006 | 08:28 PM
TurboJdmEk's Avatar
is on blocks...
Default Where Can I Get A Good Write Up On Swaps???
I Am Looking For A Good Detailed Write Up Of How To Swap A Full B16a1 Vtec 5spd Trans.(w/lsd) Into A Ef Civic Hatchback Already 5spd And Maybe How To Run Vtec Wires If It Wasnt Already Everything Please Someone Help Me Out Thanks, John
its coming...
Old Apr 7, 2006 | 08:34 PM
djlobes's Avatar
Im sofa king we todd did.
http://www.jspecautosports.com/TechCenter.aspx#Honda
aslo try www.hondaswap.com
Old Apr 7, 2006 | 08:58 PM
Civickid5835's Avatar
this is to convert the wires/wiring harness
http://rywire.com/store/index.php?os...a5dffdc3e2ce6b
Old Apr 7, 2006 | 09:14 PM
TurboJdmEk's Avatar
is on blocks...
thanks alot keep them coming
its coming...
Old Apr 7, 2006 | 09:21 PM
TSX24L's Avatar
www.hondaswap.com
Old Apr 7, 2006 | 10:05 PM
its hard to find a write up, try honda-tech.com
but you will need motor mounts, shift linkage, and axles, thats for sure
Old Apr 7, 2006 | 10:32 PM
TurboJdmEk's Avatar
is on blocks...
heres a list of everything i will be receiving with the swap:
  • Motor
  • Transmission
  • Engine Wiring Harness
  • All required Cables
  • Lsd
  • ECU
  • Distributor
  • Complete Intake Manifold
  • Alternator
  • New Axels
  • A/C
  • Power Steering Pump
  • All Brackets and Sensors
  • Shiftlinkage
is there anything else i will need to do the swap also it is a standard hatch so i need a write up (and parts list)on going from multi-port to fuel injected right?? or sonmeone could judt explain how in the post that will help to thanks, john
its coming...
Old Apr 8, 2006 | 05:56 AM
TurboJdmEk's Avatar
is on blocks...
its coming...
Old Apr 8, 2006 | 07:05 AM
sprayedtegra's Avatar
Fucking HONDA enthusiast
www.c-speedracing.com i believe you'll need the driver side upper engine mount also!
Old Apr 8, 2006 | 09:42 PM
lilmike13's Avatar
SAVE THE SOHC!
thx guys
93 del sol si (project)
88 honda cvic ef (daily driver)
hit me up on fb ( www.facebook.com/stewartracing13 )
TR "Old Skool EF" Member #166
