gas mileage
Old Apr 4, 2006 | 07:18 PM
topsecret101's Avatar
Default gas mileage
ok i got a 93 civic ex 135,000 miles just changed the fuel filter ran the injector cleanor whut elsecould be causing my milege to go down right now i am gettin 220 to the tank and i just changed the oil any have any idea should i go get a fuel system flush done somewhere
Old Apr 4, 2006 | 07:25 PM
integraman89's Avatar
lost u already???
check your spark plugs and wires, and air intake is a big factor, check and make sure its clean, get a good intake like K&N, if you dont have one... also some sensors can go bad causing you to burn more fuel.
Old Apr 5, 2006 | 05:17 AM
99B16Si's Avatar
if you havent already, replace:
-distributor cap/rotor
-ignition wires
-spark plugs
-fuel filter
and hopefully your check engine light is off
Old Apr 5, 2006 | 11:15 AM
did the fuel filter the the spark plugs and wires like 3000 miles ago havent done cap and rotor yet could that be the last thing
Old Apr 5, 2006 | 01:26 PM
The Spectacle's Avatar
Spent more money than you
o2 sensor...replace it ASAP
Racing Integration
LHT Performance
My tuner is named Alpha
Old Apr 5, 2006 | 03:37 PM
freakasis's Avatar
+1
and do a compression test to make sure yer not losing compression.
Old Apr 6, 2006 | 12:18 PM
ok thnaks iam about to go buy a new o2 sensor now
