need spadomner help on a 93 civic ex!
Old Mar 28, 2006 | 07:40 PM
lilmike13's Avatar
SAVE THE SOHC!
Question need spadomner help on a 93 civic ex!
my speedomner only works when it wants to and some times it just jumps around 4 a few secs then goes to normal or just sits at 0 4 a few miles then stats working or if i hit a bump hard it will stop working or stop i know these are eletrical where should i look 4 a bad conection or a losse ground or wut the dash lites sometimes goes off too and i hit the dash and theyll light right back but dose any1 know wut it could be a pervious owner of the car set it up where u have to flash the high beams to start the car maby where they ran the wiers or sumting i dk they did it relly clean i dont see the wiers that they used under the dash.
thx mike
93 del sol si (project)
88 honda cvic ef (daily driver)
hit me up on fb ( www.facebook.com/stewartracing13 )
TR "Old Skool EF" Member #166
Old Mar 28, 2006 | 10:15 PM
mustangnick88's Avatar
I don'y konw if this id your problem but vss goes out all the timein these cars.
Old Mar 29, 2006 | 03:49 AM
Blown99civicSi's Avatar
EFI Tech/Tuner
^^^^^+100 Honda VSS's go out like no tomarrow. I went through 1 already on a 99 SI with only 50K on it, It would freak out jump around play dead and then sometimes work fine.. Ebay $35-$45 brand new. works great
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
Old Mar 29, 2006 | 07:28 AM
lilmike13's Avatar
SAVE THE SOHC!
wuts a vss?
Old Mar 29, 2006 | 07:33 AM
quickex99's Avatar
Scissor Me Timbers!
up...
Old Mar 29, 2006 | 08:22 AM
lilmike13's Avatar
SAVE THE SOHC!
k nvm i found the vss on ebay thx alot guys i just hope this fixes it!
Old Mar 29, 2006 | 10:25 AM
quickex99's Avatar
Scissor Me Timbers!
would this also be the problem if the speedo and take both completely stop working??
Old Mar 29, 2006 | 12:41 PM
See if you can pull the speedo cable out of the housing from both ends.
If so, replace the broken cable. -Bob
thx mike
Old Mar 29, 2006 | 04:40 PM
lilmike13's Avatar
SAVE THE SOHC!
im perty sure its not a cable
