B-Series Question
Old Mar 16, 2006 | 01:34 PM
ilovehondas's Avatar
True HONDA Lover!
Default B-Series Question
I was told you can put a B18B1 Crankshaft and stock ls rods, are part of a stroker kit. How is this done what pistons do you need any block work. Any other site info would help I looked on HT but couldn't find info. Anything will help. Rafael
TR "Old Skool EF" Member #19
Old Mar 16, 2006 | 01:43 PM
b16a2pwr's Avatar
ALLJDM
your question make no sense. "you can put a B18B1 Crankshaft and stock ls rods, are part of a stroker kit."
WTF?
you can put a stock ls crank, rods and pistons in almost any B18 block.
can you make your question a little more specific?
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old Mar 16, 2006 | 02:09 PM
True HONDA Lover!
Here is one http://cgi.ebay.com/ebaymotors/Integ...spagenameZWDVW
I don't know if it is true, i was just looking for more info. Rafael
Old Mar 16, 2006 | 02:30 PM
sxecrow's Avatar
EG2 CRX
You're still not answering the question. What is your goal with an LS crank?
Old Mar 16, 2006 | 02:40 PM
TIM TIM TIM's Avatar
could be worse
ls rods and an ls crank will make...... an ls bottom end - pistons
aim:because tim said
Old Mar 16, 2006 | 03:25 PM
freakasis's Avatar
i think what you mean to say is:
"can i use ls rods and an ls crank in my gsr/type r block in order to incrase the stroke?"
if that is what you are asking than yes you can. because the mains are the same and the deck height is the same.....but you cannot use them in a b16 block without major work.
Old Mar 16, 2006 | 03:45 PM
95gainfla's Avatar
smokes weed...everyday.
+1.
I <3 RooR!!!!!!
Old Mar 16, 2006 | 04:27 PM
True HONDA Lover!
Thanks that's what I ment to say just couldn't say it. What's the stroke of a stock gsr and a stock ls. Thanks for the help. Rafael
Old Mar 16, 2006 | 06:31 PM
95gainfla's Avatar
B18A and B18B engines have a bore and stroke of 81 x 89 mm, which gives you 1834cc.
B18C's have a 81 x 87.2 bore and stroke which gives you 1797 cc of displacement
I <3 RooR!!!!!!
Old Mar 16, 2006 | 07:22 PM
True HONDA Lover!
Thanks to all, do you think it is worth doing and do you use the gsr pistons or have to use aftermarket.
