lower ball joint came out
Old Mar 7, 2006 | 07:39 PM
sikbluaccord's Avatar
Default lower ball joint came out
hey can anyone help me understand what happened. i was on my way to the dealership and as i was going there i was making a left turn and next thing you know i hear a loud popping noise and then a grinding sound as i slid about 5 inches. i figured the axle had snapped from the way it sounded but when the tow truck guy was putting it down off the truck i looked at it and the lower ball joint was out. here are some pictures to show you what it looks like. also as i was wondering the caster nut that goes on the ball joint where can i get it
Old Mar 7, 2006 | 07:42 PM
by the way its a 95 integra ls
Old Mar 7, 2006 | 07:53 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
The nut wasnt all the way on. THis is a classic case of half assing something.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Mar 7, 2006 | 07:54 PM
Zxc4's Avatar
when you get the nut make sure it is torqued to 47 ft/lbs and get a new cotter pin.
Old Mar 7, 2006 | 08:24 PM
the guy who did it used an impact gun to put it on i dont know if that matters
Old Mar 7, 2006 | 09:13 PM
freakasis's Avatar
never use an impact on a ball joint. but even if you did you should be fine as long as there was a codder pin....prolly didnt put the pin back in. just get a whole new ball joint there like $25 and you can put it in yourself. dont let em try to tell you that you need a press because you dont.
Old Mar 8, 2006 | 02:51 AM
the old one just looks as though it came out cant i just put it back in and if i get a new one after i knock out the old one wouldnt i have to get the new ball joint pressed in at a machine shop
Old Mar 8, 2006 | 04:31 AM
Duke_nukem's Avatar
Nope(1) and Nope(2).
(1) why put the old one back on? its probably damaged somewhat.
(2) No just place it in and torque it down.
_____________
91 Hatch B16-T
13.0 @ 110 - 7psi
--Even my Truck has Vtec--
