B18b into EG
Old Mar 5, 2006 | 07:17 PM
robunicu's Avatar
Nicolai
Default B18b into EG
If i put a 98 ls motor into a 95 civic will it be bolt on? do i need motor mounts? what else should i do? any sugestions?
PBM fender roller for rent!!
Old Mar 5, 2006 | 07:22 PM
PooN_Lude's Avatar
You should research this a bit more. There's plenty of information on the internet that will anwser your questions
Old Mar 5, 2006 | 07:26 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
You need 94+ integra mounts and linkage/axles. You can use DA axles , depending on what intermidate shaft you use.
Also you need a obd1 LS ecu IE: 92-95 pr4 or p75. Use the stock harness. If the motor is a 98 its obd2a ,so you need obd1 injectors ( or obd2 clips ) obd1 alternator and OBD 1 ls dizzy.
this information is based on IMO the easiest way....
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Mar 6, 2006 | 02:44 AM
robunicu's Avatar
Nicolai
thank you for the info
Old Mar 7, 2006 | 02:23 PM
robunicu's Avatar
Nicolai
any more ideas? should i upgrade someother stuff?i might want to go ls/vtec latter on when i get more money.....
