dropped 2" how bad will my camber wear be??
Old Feb 22, 2006 | 06:15 PM
BABYBOY8782's Avatar
BABYBOY
Default dropped 2" how bad will my camber wear be??
i have a 94 accord dropped 2" in the front and 1.5" in the rear how bad is the camber gonna be on my tires? and if its bad any suggestions on a camber kit?
thanks for any info.
Old Feb 22, 2006 | 06:25 PM
95gainfla's Avatar
smokes weed...everyday.
bad. just get it realligned.
I <3 RooR!!!!!!
Old Feb 22, 2006 | 06:29 PM
Outkasted24's Avatar
** I ♥ Old Skool **
Usually a 2" drop or less will keep your camber wear down to a minimum.
I'd still get a camber kit if I were you, but you should get many miles out of your tires before wear starts showing.
G/L
-Jeff
My Flickr
slam.poke.drop.tuck.dope
Old Feb 22, 2006 | 06:41 PM
BABYBOY
ok thanks i have a ingalls camber kit but not sure if its the right one its -3/4" to +1" will that work ?
Old Feb 22, 2006 | 07:03 PM
** I ♥ Old Skool **
yep, That'll work perfect!
Just remember....As soon as you get your camber kit installed....GET AN Alignment ASAP!!!
If you set a camber kit and drive with it without an alignment....It'll feel like your driving on ice skates...Pigion Toe'd
My Flickr
Old Feb 22, 2006 | 07:38 PM
BABYBOY
anyone knwo where in town and country i can get an alighnment and camber adjusted for a fair price? thanks for all the help guys
Old Feb 22, 2006 | 10:06 PM
kender's Avatar
gadget man
check the alignment shop sticky, alot of places will brush you off as soon as they see your car is lowered. I called around when my crx was done and had to go to st.pete to get someone ( I live in riverview), but this was years ago, I am due soon so I'll be having the same headache. depending on the car the camber kit you have may be ok or it may not. when my crx was dropped 2" it was 3 degrees off.
U.S.S.A Crew Member #001
Old Feb 23, 2006 | 06:11 AM
lowoctane's Avatar
Professional Dumbass
it will most likely be off about 2degrees in camber in the front. and your toe will be off really bad also. i would recommend a camber kit and an alignment right away. i had to purchase new tires about every other month, due to how i drive and how bad it was off.
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old Feb 23, 2006 | 01:01 PM
accord95's Avatar
USMC
i drove my car for 6 years with a 2 inch drop and had very minor tire wear. i purchased the ingalls camber kit for mine and took it to Fred Cox automotive on florida ave. they are the best place for lowered hondas, they did the camber and toe for me and everything is perfect.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Feb 23, 2006 | 01:21 PM
robofunc's Avatar
rocktastic
Too much negative camber will cause uneven wear, but not as much or as quickly as toe in/out.
If you want a quick fix until you can get a proper alignment, let me know and I'll write up & PM instructions for getting your toe as close to 0˚ as possible with an 18" ruler and measuring tape.
