Mounts question
Old Feb 20, 2006 | 10:42 PM
boostedb16a3's Avatar
Equal Opportunity Hater
Default Mounts question
Where the hell can I find some solid mounts for my sohc build? Its for a Z6 into a 90 hatch. I have oem mounts that I had filled with poly, but that shit is ghetto, and they will probably break on me. I checked Hasport, and JimFab is not fabricating due to some new project. I think im fucked.
-Joe
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
Originally Posted by JAVIELITO
limpio as fukk
Old Feb 21, 2006 | 03:16 AM
95gainfla's Avatar
smokes weed...everyday.
not sure, but check arizona race.
I <3 RooR!!!!!!
Old Feb 21, 2006 | 06:35 AM
freakasis's Avatar
if you filled them with poly the right way....and let em dry right than you should be fine....iv never had a problem with mine.
Old Feb 21, 2006 | 06:50 AM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
prothane inserts homie, thats all i run.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Feb 21, 2006 | 08:47 AM
YBlegal's Avatar
Broke not Built
i have poly filled mounts, and have never had a problem with them....alsong as you do them right you should be fine....but also like cold_beer said, prothane inserts are good also....plus there somewhat cheap...
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Feb 21, 2006 | 11:30 AM
thanks for the info guys. Keep any other ideas or leads to a manufacturer that sells solid mounts for a sohc into an 88-91 civic/crx.
limpio as fukk
Old Feb 21, 2006 | 12:38 PM
SmokinS13SR20's Avatar
That ginger...
Id go solid motor mounts on something like boostedb16a3 is doing.
Besides that i would only fill them if i was desperate or didnt really fell like spending money on the solid. But the solid/inserts seem to rattle to much.
So on a DD application i would go OEM or fill (they seem not to rattlle)
My $0.02
PS:~ Fuck yo cough NIGGA!!
Old Feb 22, 2006 | 09:59 PM
so pretty much with the inserts you insert them into an oem mount with a pin that goes through? Might be a stupid question but I have never dealt with inserts.
limpio as fukk
Old Feb 24, 2006 | 10:10 PM
warpd's Avatar
Yeah they are pretty inexpensive too. you can buy them here locally at automotive engineering. All they do is fill the void that stock mounts have to eliminate vibration. its two halves that you squeeze together with these "super zip-ties". good shit
(813) 523-0168 Sid
(813) 476-5383 Justin
Old Feb 25, 2006 | 06:25 AM
lzylst's Avatar
Energy suspension inserts are softer than prothane inserts. I personally have the prothane mounts and like them , plus they were under $40 for the 3 main engine mounts.
The driver side was a pain because you had to take a torch and cut out the old mount/sleeve. This was on a DA chasis.
