turbo questions
Old Feb 10, 2006 | 08:24 PM
95DohcAccord's Avatar
slamed
Default turbo questions
DO I have to weld in the oil pan for the turbo drain line? Is there another way around that in a h22? And does anyone recomend a place I can get my ecu tuned at for the turbo?
Old Feb 10, 2006 | 08:41 PM
Jap's Avatar
Jap
VTEC Out
Yes you must tap the oil pan for a drain . Be sure to do it in the correct location for your setup or have a professional do it ....
Tunning ?
www.Phearable.net
MTBER is the man around here
Hondata saves lives
Old Feb 10, 2006 | 09:00 PM
mtber's Avatar
Tunning ?
www.Phearable.net
Thank you for those kind comments sir
Concerning the oil return, make sure you have a fitting installed into the proper location. http://honda-tech.com/zerothread?id=588934 gives you an example.
Old Feb 10, 2006 | 11:55 PM
YBlegal's Avatar
Broke not Built
plus 1 on the tuning by MTBER seen his work on a couple cars...good stuff!!
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Feb 11, 2006 | 05:12 AM
DANGERANGER's Avatar
Shop Bitch
Also make sure drain is right size!
Old Feb 11, 2006 | 06:14 AM
Zxc4's Avatar
there are weld-less plugs, but it's probably a good idea to get one that welds in. From what im aware you want the plug in the "deep" part of the pan at almost the highest point possible, and avoid hitting the downpipe with your oil line.
Old Feb 11, 2006 | 10:57 AM
mtber's Avatar
Thanks bud
Old Feb 11, 2006 | 11:23 AM
95gainfla's Avatar
smokes weed...everyday.
you COULD get a weldless drain plug, and jbweld aroound the seems of it. im thinking about doing it, just to see if it'd work. maybe ill do a write up if it works.
I <3 RooR!!!!!!
Old Feb 11, 2006 | 12:35 PM
YBlegal's Avatar
Broke not Built
i know a couple of people to just drill out a hole and tap it and thread a fitting into the pan with no leaks or problems....
Old Feb 11, 2006 | 12:37 PM
95gainfla's Avatar
yea, thats what i was gonna do, but put jbweld around the edges for security...
I <3 RooR!!!!!!
