JDM itr conversion?
Ok Ive got the whole front end on now,But I have one problem the latch doesnt work.For one the cable is not long enough and two the latch is like slammed agaisnt the hood so I cant even lift it.I have heard that I have to use a 90-93 cable for this.Is that true if you could please give me some info that would be great.Maybe a website or something.
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
Originally Posted by zuir18
by the way the conversion is on a 99 integra
Cost something in the $15 range.
just find a vehicle with a long nose and odds are you'll get a long enough cable to work.
As for the latch, You can adjust those with a few turns of the 10mm or 12mm (I forgot the size) bolts holding the assembly on.
G/L
you need a 90-93 Integra cable, and the hood latch from i believe it is a 98-02 accord.
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
