h23
Old Jan 1, 2006 | 09:02 PM
Kernon's Avatar
RIP PABLO THE MAN GARCIA
Default h23
can i use any h22 parts on the h23
Old Jan 1, 2006 | 09:52 PM
VOD's Avatar
VOD
Field Rep
i dont see why not cms used parts offa my h23 on my my jdm h22...i think thay might still have my h23 ova there..i snapped the belts and bent the rods..i think thay were sellin it for $300..talk to kris
Old Jan 1, 2006 | 10:03 PM
PooN_Lude's Avatar
you can swap an h22 head onto the h23 bottom end (h23/vtec) the header flanges are different, exhaust and intake are the same..its the same series son, its all good ..what parts are you reffering to?
Old Jan 1, 2006 | 11:34 PM
Kernon's Avatar
like pistons,rods,
Old Jan 2, 2006 | 01:05 PM
blurboEK's Avatar
proud father ;D
Originally Posted by silvia240sx
like pistons,rods,
Pistons will swap over, unless your decked you'll need to swap over the H23A1 crankshaft to use the H23A1 rods. H23/H22 block castings are indentical, differences are all internal and most parts are interchangable with the exception of intake/exhaust manifolds (upper portion of H23A1 intake manifold is the same as H22A/1/4), obviously head internals are not interchangable as the H22 has a VTEC lobe where H23A1 does not, valves should be the same dia though. Distributors are interchangable along with all of the sensors. Cam gears are different, although H23A1 cam gears have the same teeth as B-series. Timing componets are different (teeth wise), H22A/1/4 uses a hydo tensioner for the timing belt where H23A1 uses manual (you can swap hydro for manual and vise-versa), crankshaft pulley is the same, flywheel/clutch are the same, axles/inter. shaft the same, accessories like a/c, p/s, etc are interchangable. If you have any other questions feel free to ask.
-Mike
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
Old Jan 8, 2006 | 11:23 PM
Kernon's Avatar
so i can use the h22 valves and valve springs jus not cams and rocker arms and stuff like that
Old Jan 9, 2006 | 11:28 AM
blurboEK's Avatar
proud father ;D
Valves may be the same size, check and see if they're the same part number. H22A/1/4 valves are dual springs where H23A1 are single. If you're building the motor I'd just go aftermarket, atleast then the pieces will be made to fit your application.
-Mike
Old Jan 11, 2006 | 05:20 PM
TxTurbo's Avatar
MILF HUNTER
im in the process of builting a H23 VTEC... and if u need any info just ask " wilp99 " bump to the man...
