Got the swap in, car no start..
Old Nov 29, 2005 | 03:05 PM
davcivic's Avatar
El Mas turboso
Default Got the swap in, car no start..
Well after 3 days of crap doing a swap by myself in the backyard I finally got everything in and done.
I went to start the car it cranks but it wont start. I have no fuel pressure and I can't hear the main relay click or the fuel pump turn on.
Damn it, I drove the car to where it is, took one engine out put another one in.
I need to check fuses and the main relay.
Any other ideas????
92 Integra LS
B16A
Chipped P28 it was running in the other car, so ECU is working.
Thanks
2002 Subaru WRX
1988 Honda Civic Hatch
Old Nov 29, 2005 | 03:22 PM
rangcrx's Avatar
engine building &best
make sure your grounds are on like the main ground the 1 that goes near the thermo,Make sure your res box plug is pushed all the way in make sure all ecu plugs are all in,but im guessing a ground or even the distributor plugs but check everything again
i love AUTOZONE
Old Nov 29, 2005 | 04:57 PM
davcivic's Avatar
El Mas turboso
Originally Posted by Keith
"I went to start the car it cranks but it wont start. I have no fuel pressure and I can't hear the main relay click or the fuel pump turn on."
why do you need us... you have your work cut out for you already... check that shit and get it working and then go from there...
That's because I know my shit, but some of you guys know more than me, specially the chavez people , so I figure I would ask and see if I was overlooking something else.
I mean the car drove fine 3 days ago to my backyard, did the swap, and now I have no fuel. Unless it is bad grounds or I missed one and the fuel pump or main relay is not getting good grounds.
Thanks for your help.....
2002 Subaru WRX
Old Nov 29, 2005 | 06:17 PM
95gainfla's Avatar
smokes weed...everyday.
blown fuse?
I <3 RooR!!!!!!
