Oil pressur problem
Old Nov 20, 2005 | 09:11 AM
mafro's Avatar
Default Oil pressure problem
I have a 1995 accord. The car has oil and the oil light has been blinking and i dont know why. I dont know a hell of a lot about cars. I just know its been blinking a lot but it doesnt blink when the car is over 2500 rpm. Does anyone one know what this could be. Any help would be greatly appreciated.
Old Nov 20, 2005 | 02:28 PM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
low oil pressure could be caused by many things...Bad oil pump, loose clearances, bent or damaged oil pickup tube.
Do not keep driving that thing or a new engine is in your future. Did you run over something recently? Did anything happen that may cause this to happen or did it come out of nowhere?
Mileage on car?
Now residing in Atlanta.....
Old Nov 20, 2005 | 07:18 PM
95gainfla's Avatar
smokes weed...everyday.
change your oil/oil filter
oil light on=BAD news for your engine.
When you open the oil cap, does a lot of smoke come out?
I <3 RooR!!!!!!
Old Nov 20, 2005 | 07:32 PM
davcivic's Avatar
El Mas turboso
Open your oild cap and look inside, with the car turned on, do you see oil running around the cam, or jumping outside. If yes, more than likely everything is fine. Your oil pressure sensor could be bad. It hapenned to me, I started freaking out about it, I was about to buy a whole new engine, because I'm paranoid like that. It was just the oil pressure switch and only $6.99. If you can't see oil, you have to look deeper into it.
Good Luck
2002 Subaru WRX
1988 Honda Civic Hatch
Old Nov 21, 2005 | 12:32 PM
mafro's Avatar
well the the light only comes on during low rpms anything ove 2500 rpms it is fine the oil pan is dented which is recent so i dont know if that is part of the problem but i think the oil pump is going bad
Old Nov 21, 2005 | 01:03 PM
BACON's Avatar
VALE TUDO!
my integra did this
i found out that it was a faulty oil pressure sending unit
Your car club is gay...
Old Nov 22, 2005 | 03:54 PM
rangcrx's Avatar
engine building &amp;amp;amp;best
Good Luck
where did you buy a honda oil pressureswitch for 6.99?
i love AUTOZONE
