trunk alignment issues... 99 civic coupe
Old Oct 27, 2005 | 11:12 AM
quickex99's Avatar
Scissor Me Timbers!
Default trunk alignment issues... 99 civic coupe
Well I recently traded my oem trunk lid with an si spoiler for a oem trunk lid w no spoiler ... Well When i put the new trunk lid on it sits kinda crooked the drivers sides sits higher than the passenger side... and because of it there is a slight gap.. I was wondering if anybody knew an alighmnet secret or the easiest way to fix this problem.. thanks
Old Oct 27, 2005 | 12:08 PM
quickex99's Avatar
Scissor Me Timbers!
Old Oct 27, 2005 | 12:50 PM
joebobclark's Avatar
Your Moms New Boyfriend
Mine was tweaking to one side like that when I tightened the bolts all the way done with it open.
I just left then slightly loose and shut the trunk down with the backseat folded down. Adjusted it by hand to get the gaps right, and went in through the backseat to tighten the bolts to spec.
Hope it helps.
Good luck
Old Oct 27, 2005 | 12:53 PM
quickex99's Avatar
Scissor Me Timbers!
Thanks mang.. i will try it tonight!!!
Old Oct 27, 2005 | 02:05 PM
Outkasted24's Avatar
** I ♥ Old Skool **
Hope it helps.
Good luck
I have the same problem, Gonna go play with the trunk now.
My Flickr
slam.poke.drop.tuck.dope
Old Oct 27, 2005 | 04:30 PM
[QUOTE=joebobclark]Mine was tweaking to one side like that when I tightened the bolts all the way done with it open.
I have used pieces of wood, or folded cardboard to get them even.-Bob
Old Oct 28, 2005 | 04:59 AM
quickex99's Avatar
Scissor Me Timbers!
Well I Tried And It Helped A Little Bit.. But It Is Still Pretty Uneven...
Old Oct 28, 2005 | 02:09 PM
95gainfla's Avatar
smokes weed...everyday.
hopefully you get that figured out!
mine is uneven too, it doesnt seem to go all the way down on the bottom left side of the trunk..like...where the light is?
any ideas?
I <3 RooR!!!!!!
