b18 axles??? help
Old Oct 13, 2005 | 09:06 PM
FC_V8's Avatar
Default b18 axles??? help
are the axles for the b series all the same excluding ls (non-vtec). n what about abs. are abs axles interchangable with other b-series w/out abs? how bout i say it like this, i have gsr axles that came out of the teg with abs, will that fit into my civic w/out abs? some ppls say yes, some say no ?? im lost
Old Oct 14, 2005 | 08:38 AM
dohcvtec's Avatar
You boys like Mexico!!!
Ok if u need axles for a gsr u use axles for a gsr...u need axles for a ls then u get axles for an ls....a gsr is different because on the drivr side it had a male end that the axle nut goes on and the other side is a female end that slides onto the intermediate shaft....
Old Oct 14, 2005 | 08:39 AM
Derka's Avatar
TR Balla Donor Supreme
If you dont have abs you can still use an abs axle, the only different in the ring on the end of the axle so the abs sensor can measure movement.
1998 crv daily beater
Old Oct 14, 2005 | 09:32 PM
FC_V8's Avatar
thanks derka, new problem, i think while pulling out the axles from the teg, i may have pulled it too hard n the bearings in the boot pulled out and wont go back in. is there any way for me to fix that?
Old Oct 14, 2005 | 10:47 PM
dohcvtec's Avatar
Buy new ones
Old Oct 14, 2005 | 11:11 PM
Derka's Avatar
what exactly are you trying to do? does your car need new axles, or are you doing a swap?
Old Oct 16, 2005 | 05:40 PM
FC_V8's Avatar
oh i was just doing the swap and came across it...j/w....sorry for the late reply...almost got it in...by monday i should get it...
