Piston to deck height....**question**
Old 10-13-2005, 07:31 PM
Rockin' 4 more Cylinders
Cold_Beer's Avatar
werd. Thanks man
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old 10-14-2005, 05:08 AM
KJ
bored at work
KJ's Avatar
no you are in the whole .9mm which equals about .03". You are good, that is normal.
Old 10-14-2005, 06:04 AM
freakasis's Avatar
Originally Posted by Cold_Beer
ok so....
Deck height - (stroke/2 + rod length + compression height) = piston to deck
212.39 - (87.2/2 + 137.90 + 29.9974) =0.9
so piston to deck heigth is 0.9mm
meaning the piston is sticking out 0.9mm @ TDC
anyone second this?
if the compression height is (stroke/2 + rod length + compression height)~211.4974 which is less than the deck height then no you are still in the hole. a negative value would mean that your compression height is higher than the deck. and you would be out of the hole. because of the order you did the subtraction.
Old 10-14-2005, 08:03 AM
vertigo_16201's Avatar
nerds
Old 10-14-2005, 08:28 AM
99B16Si's Avatar
defintely dont use a standard bore headgasket. imagine how hot such a thin piece of metal would get in the combustion chamber since it would be hangin over the edge....probably would cause some serious detonation
Old 10-14-2005, 10:07 AM
Cold_Beer's Avatar
Thanks for the info guy
_Jake D
Old 04-20-2019, 06:40 PM
  #17 (permalink)
A bit more
https://www.tamparacing.com/forums/a...ml#post9419226
omgosh
11-11-2010 04:50 AM
GNs-r-slow
09-26-2009 04:57 PM
3G_preludeSi
11-23-2004 08:12 AM
MotorMatrix.com
11-21-2003 12:09 PM
Red01SS
09-22-2003 08:45 PM
Quick Reply: Piston to deck height....**question**
