dual to multi + ecu ?
Old Oct 3, 2005 | 10:17 PM
bigwheelsocala's Avatar
Exclamation dual to multi + ecu ?
How do i go about converting over to multi point I have a 91 civic hatch
and its dual ...i converted it all over to manual.but i also still have the auto
ecu will that be a problem to ?because i have heard that 2 injectors work at the same time but i need a box of some sort ..thank you
Old Oct 3, 2005 | 10:35 PM
Bserieskllr's Avatar
you might as well get a 5speed pm6 si ecu or even a pg7 ecu....btw you need to change the ecu anyway.
92 240sx Vert-Drift car-CA Powa!
91 Civic Si-Minty Fresh-Boosted B20/Vtec
01 IS300-DD beater-2JZ no shit
Old Oct 3, 2005 | 11:45 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
pick one.
http://www.geocities.com/teampimports/fuelinj.html
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
http://www.geocities.com/c_rexboy/mpfi.html
http://www.bladesilver.net/crx/
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Oct 5, 2005 | 07:35 AM
what about the injectors ? dual to multi ? i got a obdo harness
Old Oct 5, 2005 | 07:49 AM
davcivic's Avatar
El Mas turboso
Read the links,
basically you need
1) Complete MPFI Intake manifold, all the sensors, injectors the injector clips/wires, from the same year car, 88-91
2) Injector Resitor Box
3) 88-91 Civic/CRX Si or HF distributor
4)PM6 ECU 5spd, 90-91 preferibly can be chipped, the older ones are a bit different. Or PG7 5spd ECU from 88-89 Integra.
Then extend some wires, change some pins in the ECU and you are done.
Read the links for more detailed information.
2002 Subaru WRX
1988 Honda Civic Hatch
Old Oct 5, 2005 | 07:50 AM
davcivic's Avatar
El Mas turboso
Also just use your STD/DX harness, all you need to do is extend 2 wires and add 4 for the injectors, really easy to do, a lot easier than swapping everything out.
Trust me, I've done this a few times already.
2002 Subaru WRX
Old Oct 5, 2005 | 10:21 AM
Cold_Beer's Avatar
did you not click on the links above?? come on now.
_Jake D
Old Oct 5, 2005 | 07:54 PM
dippincrx's Avatar
save the s.o.h.c
the mpfi swap is alot easier than it looks just do some research
Old Oct 5, 2005 | 08:01 PM
methree's Avatar
loser x.x
+1 for easy
i dont know why people dont take me seriously....now wheres my crack pipe
