Low Compression?
Old Sep 29, 2005 | 07:25 PM
skunked_rex's Avatar
window shopper
Default Low Compression?
i plan on running an ls block with gsr internals. im going turbo so it needs to be lower compression. how do you know the precise compression you need for your setup? the lower the better?
Old Sep 29, 2005 | 07:57 PM
window shopper
i meant aftermarket gsr internals. see my ls/vtec post maybe you can help. i wanted to know the pros and cons of lower and higher compression on turbo motors
