how do change a head gasket????
Old Sep 27, 2005 | 08:12 PM
bishopsol3's Avatar
Default how do change a head gasket????
i have a honda d15b7 motor and it needs a new head gasket b/c its leaking oil, ive never took the head off before or have changed out a head gasket, if some one coudl plase explain to me how hard it is or wut to do, thanks
Old Sep 27, 2005 | 08:18 PM
Slo_Si's Avatar
$200 Motor!
its leaking oil? you sure its not the valve cover? its very simple...
- Officially Retired....for now...
Old Sep 27, 2005 | 08:28 PM
BLUE2KSS's Avatar
Mechanical Engineer
+1
Old Sep 27, 2005 | 09:06 PM
vonrobins's Avatar
love hondas ftw
take it to a mechanic or do it ur self and have fun --yeah rite
._________________________
Old Sep 27, 2005 | 09:14 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
http://www.honda-tech.com/zerothread?id=1100617
that should help.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Sep 27, 2005 | 09:46 PM
Sabotage's Avatar
slash
if you're talking about the valve cover, then that is very easy....i noticed people that would come into my store would get head gasket and valve cover confused and half the time they said head gasket, they meant valve cover gasket, which is the one that is on the top and is the easy one so hopefully thats the one you need!
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
Old Sep 28, 2005 | 04:06 AM
methree's Avatar
loser x.x
yeah, i think its the valve cover as well...
i dont know why people dont take me seriously....now wheres my crack pipe
Old Sep 28, 2005 | 05:03 AM
Slo_Si's Avatar
$200 Motor!
this is too funny...
Old Sep 28, 2005 | 05:29 AM
methree's Avatar
loser x.x
lol, new thread after this one...how do i change my windshield wipers? theyre jdm....lol
Old Sep 28, 2005 | 07:13 AM
chi town brat's Avatar
! Ne shab'rud'ni !
check for coolant in your oil ... a blown headgasket will let them mix.
also could be the o-ring on the distributer ... no matter how many times i've replaced mine on the sohc that bish still leaks.
I would suggest you have a friend or mechanic look at it to determine where the oil leak is coming from first.
After determining where it is at then proceed to get a good tech manual or a good internet link on how to replace the headgasket, you wouldn't really need a manual for a valve cover gasket. BUT YOU WILL FOR A HEADGASKET.
It has the proper way to torque down the headbolts after replacing the gasket. You'll want to make sure you don't put digs into the block or the head when you go to remove it. And since you have the head off its all nice to have it milled to have a nice clean seal before putting it back on.
Also becareful not to put the headgasket on upside down, sounds impossible or stupid but it can happen.
After you put it back together you'll need to set the timing and that requires having the engine to TDC.
There is a lot more than this. So I will say if you choose to take it on yourself have someone help you out, walk you thru it or take it to a shop where it can be done.
For the headgasket, if you are running a normal OEM setup spend the $$$ on the OEM headgasket.
