Cleaning engine bay
Old Aug 30, 2005 | 12:10 PM
DA92driver's Avatar
Default Cleaning engine bay
what needs to be covered besides air filter, and dizzy? and is it a good idea to cover the spark plug holes with masking tape? plan on using simple green tooth brush and sprayin her down. never tried it before, thought id see if any one made any mistakes the last time they did it.
Old Aug 30, 2005 | 12:31 PM
integra's Avatar
90% grind 10% sleep
yes cover the spark plug holes distributor and battary and intake i just did it about a week ago with a pressure washer and it came out great
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Aug 30, 2005 | 01:59 PM
freakasis's Avatar
yes, cover those and spray everything down with purple engine degreeser, then let it sit for about 2 or 3 minutes and pressure wash it off. no toothbrush needed. if you dont have a pressure washer use one of those do it yourself car washes and use the rinse setting. it will work great. if you wanna get the underpart you will need to jack it up, and the frown upon that so dont get caught.
Old Aug 30, 2005 | 03:01 PM
DA92driver's Avatar
alright thanks for the help. but if i use the wash yourself place, doesnt your engine have to be cold?
Old Aug 30, 2005 | 03:13 PM
rangcrx's Avatar
engine building &best
hehhe god i love people that do this,thay are the ones that make me the most money pm me when you need a engine rebuild
i love AUTOZONE
Old Aug 30, 2005 | 03:15 PM
freakasis's Avatar
i never had a problem. i mean dont race it on the way there or anything like that.
also, you can clean everthing if your plugs are oem and they seal properly and your dizzy cap seal is good, then you dont have to cover anything but the intake.
Old Aug 30, 2005 | 09:01 PM
CB7 Type R's Avatar
the Nemesis
You can do it in your drive way (if you have one) When I did it I covered all of the electircal connections, ac compressor, power steering, alternator, pretty much anything that could collect water and is electrical. And remember all you want to look good is the paint so just spray the paint not everything. I used simple green with cup and bucket, and toothbrush. The shit came out looking brand new, and my car is white and 14 years old so. If I was going to do it again I would use a tooth brush. Best of luck
In Europe Honda released the Accord with the H22 engine, they called it the Accord Type R!
