vtec problems
Old Jun 23, 2005 | 08:44 PM
run4fun's Avatar
Default vtec problems
car runs good except for one thing. NO VTEC, I have no codes. It drives through all the gears fine but when I go to ENGAGE the vtec, it starts sputtering and loses power and MLI comes on but goes off after the rpm drop below 4500 then the cars runs normal again. No codes stored in ecu........... with the solenoid or pressure switch disconneted, it runs great like a NONVTEC motor but I've got a b16a w/ a pr3 ecu.............anyone ? ? ? ?
Old Jun 24, 2005 | 07:52 AM
freakasis's Avatar
did vtec work before? is this a new swap? put power directly to the vtec solinoid and see if it works. how is your oil level?
Old Jun 26, 2005 | 03:26 PM
run4fun's Avatar
all the above checks out good rewired the motor and still getting the same results.......
Old Jun 26, 2005 | 03:40 PM
TurboEK's Avatar
Do you have good oil pressure?
Also, is that pr3 chipped? If so, the map on the chip might be garbage.
Old Jun 29, 2005 | 08:05 AM
240Dreamin''s Avatar
Check the ECU and if thats not it you might need a new solenoid the are know to go bad in the b16a's
Old Jun 29, 2005 | 09:52 AM
SpyderHatch's Avatar
Oil is low of you have a dented oil pan Or you have a bad pressure switch.
Old Jun 29, 2005 | 11:00 AM
rangcrx's Avatar
engine building &best
i have personal never heard of or seen one go bad even from a 1st gen you might want to have someone check your wireing or find someone with another pr3 ecu,is it wired up.remeber just putting a ecu in a crx does not give it vtec it has to be wired up
i love AUTOZONE
Old Jun 29, 2005 | 02:13 PM
yeah my friend just replaced his it was bad and when he did it ran great! Here's a site that you could read up on about VTEC it might help you out
http://www.asashop.org/autoinc/jan2005/techtips.cfm
Old Jun 29, 2005 | 02:20 PM
iskate2's Avatar
wears black
take off the solenoid and clean the screen- it might have a bunch of shit on it.
Quote; Stan Marsh from "Southpark", concerning his friends Cartman, Kyle, and Kenny obsessing over facebook:
"You guys are retarded, I'm playing XBOX."
Old Jun 30, 2005 | 06:50 AM
EP1491's Avatar
Boared Over
Definately check the screen, also, when was the last time you changed your oil and what weight are you using? I have had many of my friends have this problem and after they changed their oil, vtec worked like a champ.
