Does compression test #'s tell comp ratio??
Originally Posted by NChatch
but as you can see the higher the numbers jamie the better the chance of your compression being closer to where it is supposed to be, now was the compression calculated for your motor based of a vtec or non vtec head? headgasket? this is also where some of it gets tricky. but with numbers like 270 i would say its pretty close. was this done with the throttle held wide open while cranking the car over???
funny my civic only reads 155!
Yea that was with the throttle held wide open...Ive got a another ?? for you guys but I'll start a new thread.....
Originally Posted by alternativeauto
I almost buried the needle on my compression guage back around to the pin at Zero. 375ish I think, no #'s on that part of the guage. NA is not gay at those pressures ; ) .
My static compression is at 270 on my sohc. We used the compression calculator to find my ratio.
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Originally Posted by chi town brat
I broke a compression guage ... but that was because we did it after i ran the car thru the autox several times ... don't do a compression test when your engine is hot. you break things and of course you don't get the correct reading
Using a compression tester to determine compression ratio is not a good idea
Good...I could not figure out the comp ratio..The guy I got the block from was not to sure on the comp ratio either..Thanks for the info this helps me out alot now I know what I can do to it with out blowing it up
still GAY!
when you max an autometer boost gauge and your motor still purrrrrs like a kitten, let me know! hahahahah JK.
Been there,and done that MANY times
Not on this one though hahaha
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
