question about using gsr main bolts ..
Old May 11, 2005 | 01:19 PM
TSX24L's Avatar
Default question about using gsr main bolts ..
Rang if you reading this I need your help soon. I ordered the azracemachine block girdle. Iam going to need the gsr main cap bolts for the length correct? I need to go down to acura to order the bolts just want to make sure first. Let me know soon. Or if anyone knows this answer.
Old May 11, 2005 | 01:20 PM
TSX24L's Avatar
Here is the crankshaft girdle iam using .. .
http://www.azracemachine.com/CrankGirdle.htm
Old May 11, 2005 | 01:22 PM
TSX24L's Avatar
"Designed to utilize readily available GS-R or Type R Main Cap Bolts, Oil Pump Pickup, Windage Tray, and Oil Pan."
nevermind
Old May 11, 2005 | 02:26 PM
rangcrx's Avatar
engine building &best
for as much as you will pay for the new bolts you can order arp.if you want gsr bolts i might have them i will have to look
i love AUTOZONE
Old May 11, 2005 | 02:44 PM
TSX24L's Avatar
I can get the gsr bolts pretty cheap from my work. The arp are studs though and not bolts. I think aren't they?
Old May 11, 2005 | 04:36 PM
rangcrx's Avatar
thay have both thay can order to size or you can use the main studs i think the stud kit numbers are 208-5403 for the b18c1
i love AUTOZONE
Old May 11, 2005 | 05:25 PM
TSX24L's Avatar
would i be fine just using gsr bolts?
Old May 11, 2005 | 05:33 PM
rangcrx's Avatar
Yes More Then Fine If Your Buying New Thats Even Better.damn You Will Only Need The 6 Not 10....you Could Even Use To Be Cheaper 6 Bolts From The Ls/b16 Number 3 Mid Stud Thay Are The Only Like 2mm Shorter But Work
i love AUTOZONE
CXHatchback
May 26, 2002 07:18 AM
djcrx456
May 24, 2002 06:18 PM
marksaccord95
Oct 2, 2000 10:11 AM
