need some air tools help
Old May 11, 2005 | 12:15 PM
shadowboy's Avatar
insert witty retort here
Default need some air tools help
hey everyone...
i posted about a month ago about a mount that broke and pretty much ended up damaging my t-belt.
well, ive had a shortage of available time, but i have got the mount replaced. the issue du jour right now is the timing belt.
i'd really like to save the $$ if i can and do the belt myself, but i lack the tools to remove a certain crank pulley bolt.
i was wondering if anyone could help me out by bringing some air tools my way so i can get that bolt off to change the belt.
i'll pay for your fuel coming out this way (i can't do it too soon because i have to get the belt and the tensioner pulley first).
just as a note: there are no nearby outlets, so an electric compressor probably wouldn't work.
Shawn
The answer to your question is sqrt(pi)
Old May 11, 2005 | 01:12 PM
MacGruber's Avatar
MaDe Of MoNeY
I dont know of any portable tanks that are going to hold enough pressure to get that bolt off with an impact. My impact gun sucks ass and wouldnt get it off. sorry free bump for you
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old May 11, 2005 | 01:23 PM
lead's Avatar
I'm Awesome
take off your fly wheel cover and stick a big screw driver in there to hold it in place then take off the nut, you don't need air tools not to mention you would need a big air gun to get that off like a 700 lb + impact gun i know my 500 lbs one didn't take it off. or you could do some backyard mechanics and throw on a breaker bar and turn over your engine a few times, that will get it off.
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Old May 11, 2005 | 01:31 PM
shadowboy's Avatar
honda = CCW turning engine = bumping the starter will TIGHTEN the crank pulley bolt.
i can't really use anything BUT an impact wrench. i wouldn't be able to get enough leverage on a breaker bar cause i don't have enough "extension" to get the bar out of the wheel well, and in that scenario the torsional force would probably just snap an extension. ultimately it leads back to the idea that i don't have an extension long enough
Shawn
Old May 11, 2005 | 01:34 PM
MacGruber's Avatar
MaDe Of MoNeY
I tryed to use a breaker bar and an extesion on a single cam crank before and i couldnt get it off. good luck.
Old May 11, 2005 | 01:36 PM
lead's Avatar
I'm Awesome
i have never had trouble doing it that way
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Old May 11, 2005 | 03:01 PM
Sabotage's Avatar
slash
my friend has a van w/a generator and compressor, he can pull right up to where you need him and help you, if his van is running again that is! lol
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
Old May 11, 2005 | 03:21 PM
shadowboy's Avatar
well, since his van isn't running.. ill just drive right over!
Shawn
Old May 11, 2005 | 03:38 PM
lsrex212's Avatar
i have had to use a chain style pulley wrench a few times....works most of the time....whee are you at anyway?
Old May 11, 2005 | 04:37 PM
shadowboy's Avatar
usf
Shawn
Alan
Power Adders
16
Nov 11, 2003 08:05 PM
