need help honda techs
Old Apr 23, 2005 | 10:01 AM
alri0085's Avatar
Scuderia ALRI
Default need help honda techs
Here it is:
car: 89 CRX si OBD0
Motor: Dohc ZC JDM
1. starter sent ground to 12v side of battery (replaced starter)
2. oil and battery light are on even if the ignition is off
3. check engine light doesn't come on when the ignition is on
4.The oil and battery light only come on when I connect the engine wiring harness
here are my questions:
What module controls the check engine light?
Do OBD1 and OBD0 injectors matter?
What do you think is the problem?
Please let me know what you think, thanks
Old Apr 23, 2005 | 10:32 AM
juiced2ndgenteg's Avatar
burt wires. good luck finding them.
Old Apr 23, 2005 | 11:06 AM
B20VTECpoweredEG's Avatar
More Boost>Traction
Voltage Drop test's.
Did you check the junction connector near the battery that goes though the firewall?
Obd 1-0 injectors wont matter unless you dont put the plugs on.
Start with one problem, say the oil light. Grab a wiring diagram and start from the wire on the back of the gauge cluster, now trace it all the way to the back of the motor, if you find a burnt patch or stripped wire, than you have your problem, this is what a tech at Honda would do.
Good luck, if you need help, pm me.
MY HOME:
Originally Posted by 99AtlBlueGT
I would but I wouldnt fit in. I am out of high school and don't drink in parking lots anymore.
It is lame in the NPR/Hudson area, there are some crazy fast cars but no one comes out....we are on a "Racing" forum and all that comes to the hudson/mitchell rd. meets are like 4 cars that actually race, 32 spectators that follow everyone in there Geo's and 15 underage high school alcoholics.....
Old Apr 23, 2005 | 11:18 AM
alri0085's Avatar
Scuderia ALRI
[QUOTE=B20VTECpoweredEG]
QUOTE]
I'm going to try that, thanks.
Old Apr 23, 2005 | 11:22 AM
More Boost>Traction
[QUOTE=alri0085]
QUOTE]
Haynes manual is your friend, but if you have 60 bucks you can get a real Honda reapir manual. Even nicer.
MY HOME:
Old Apr 23, 2005 | 12:00 PM
alri0085's Avatar
Scuderia ALRI
alldatapro.com is my friend. I'm going to try to get another engine wiring harness to see if it's that one, or the one inside the dashboard that's burnt.
Old Apr 26, 2005 | 11:04 AM
alri0085's Avatar
Scuderia ALRI
I took the wiring harness off, tested it, found a few problems, stripped it, and fixed it. Oil light and battery light don't stay on anymore, my check engine light is back, main relay's working, we'll just have to see if it starts.
425cicamaro
Drag Racing
43
May 5, 2005 11:25 AM
Cronic
Sep 25, 2003 05:00 AM
