Oil Pressure Gauge Install
Old Mar 5, 2005 | 03:28 PM
JDMBlackGSR's Avatar
Gators Bitches!
Default Oil Pressure Gauge Install
Ok, I have located the stock oil pressure sender unit, and I am having trouble finding a Tbar to use to install it, the one I found will not go into the bolt hole. I want to know if there is something else I can do to install, or anyone that would install for a little $, kinda broke right now, but will do what I can. Let me know if anyone can help or any ideas. Thanx
Old Mar 5, 2005 | 04:20 PM
99B16Si's Avatar
T's are a couple bucks man, how much cheaper do u want to get??
just make sure u get the right thread sizes and youll be good to go
Old Mar 5, 2005 | 05:30 PM
juiced2ndgenteg's Avatar
the treads are 1/8"bspt(I think this is the correct name), not the standard 1/8"npt. thats why the T you bought dosn't thread in properly. I would buy an oil filter adapter that has ports for your oil pressure gauge. some people just JAM the 1/8"npt into the WRONG treads and hope it dosn't leak.
Old Mar 5, 2005 | 06:15 PM
Gators Bitches!
where can i find the oil filter adapter for my car?
Old Mar 6, 2005 | 05:29 AM
1fasthatch's Avatar
Traction Problems
golden eagle.com or ebay you can also use a 1/8 brass compression fittings when going in to the the back of the block you can get them at ace or home depot just be careful when doing it
www.artofspeedproductions.com
Old Mar 6, 2005 | 07:39 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
You dont need the stock sending unit if you have a pressure gauge, so dont worry about the T... Just put it directly in the block...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Mar 6, 2005 | 12:23 PM
Gators Bitches!
cant put it directly in the block, the hole is to close to the oil filter.
93ex
Knitting for fun and profit
9
Apr 1, 2004 10:10 AM
Cronic
Nov 7, 2003 03:04 PM
