d series turbo ?'s....
Old Feb 21, 2005 | 05:07 PM
FrankensteinMan23's Avatar
F|2ankenstEin MaN23
Arrow d series turbo ?'s....
I am bout to turbo my d series and I wanted to know if anyone knows of any porblems I am y run into so that I can prepare for htem pre install. Also if anyone knows of a good place to get a car dynop tuned PLEASE PM ME !!! thanks Justin
Old Feb 21, 2005 | 05:12 PM
NChatch's Avatar
i stepped on my weiner!
for tunig contact 60-1ek, or 99b16si, depending on which route of mangement you go.
as far as D series problems, there are only a known few.
-overheating
-headlifting
-slow......J/K
that should be it, make sure you either buy headstuds, and rod bolts, and that the head and deck are completely level, i have no idea if the motor is assembled or disassembled. but depending on power goal, yo may not run into any of these. i know most of this occurs at about the 300hp level
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Feb 21, 2005 | 06:11 PM
EludeR's Avatar
You would want to start to get that engine built up around that level anyway. Just don't comprimise on tunning ... what kind of setup areyou going to be using (if you don't mind me asking)
Old Feb 22, 2005 | 06:50 AM
JDM-Civic-Coupe's Avatar
USAF
im almost done boostin my internally stock d15b vtec. running tiall 38mm with .6 bar spring / 8.7 psi.
im not going to be near 300hp. so you shouldn't run into any problems. my friend had his done and no porblems at 8 psi. check www.honda-tech.com mucho info
-Chris
USAF
Old Feb 22, 2005 | 11:35 AM
EludeR's Avatar
-Chris
Any info on your setup ?
Old Feb 22, 2005 | 11:57 AM
EludeR's Avatar
Originally Posted by Cronic
I was running a boosted setup for almost two years with out any real problems. Until I blew the ringlands off the pistons, that was fun.
if you would like any advice from me. I would tell you to put pistons and rods in the bottom end before you boost it. Keep the compression stock. 9.2-9.6:1 is great c/r for a normal boosted engine.
Keep the boost low, around 7psi. Until you upgrade the injectors, and get some tuning.
Go with uberdata, or something light an inexpensive. Don't go for broke trying to squeeze as much hp as you can from it. Keep it simple. Dont use check valves or any garbage like that.
A good turbo to use is a t3/t4 .48 a/r on the exhaust. A 50 trim, or 57 trim works VERY well on D series Hondas. They will make a LOT of power on lower boost levels.
expect over 200whp very quickly with low amounts of boost. So be prepared.
What kind of manifold setup where you using , intercooler , e.t.c. ?
Old Feb 22, 2005 | 12:22 PM
NChatch's Avatar
cronic wasnt running anything crazy or expensive, like he said it was 2 years ago if not maybe a little more. but he did have some decent tuning for a while.
i saw him hang with a cobra and he had like almost no compression in one cylinder!!
owner/operator
Old Feb 22, 2005 | 10:03 PM
F|2ankenstEin MaN23
I was gonna hve my car dyno tuned at Ramsey Performance...umm I was gonna run and intercooled t3, with and SAFC,manual boost controller, and upgrade the fuel system and I need some opinions on fuel upgrade like wut size injectors and wut not....
