d16z6 turbo
well i wanna turbo the ol single cam. i am piecing together a turbo right now. got almost all parts. just to check i need the turbo, intercooler, oil lines, manifold, and what else. also i wanna run about 10psi on my motor so i wanna know what i need to build up to do this safely? thanx
fuel injectors,safc or fmu, cold plugs, a clutch , fuel pump
why would i need a clutch, and what are cold plugs? also what would be a good fuel pump to use and what size injectors?
ttt antone?
your going to need a clutch soon bc your stock clutch isnt going to be able to support this extra power you are going to try and put down to the ground. When he was referring about cold plugs he was talking about the spark plugs. Just get a set of colder plugs. ngk makes a pretty dececnt colder plug. you get to chose your differnt heat ranges. I would say for your application I would go with automatic eclipse gst injectors. reason being if you dont need 450cc. for the fuel pump a decent walboro would do you good. and lots and lots of tunning. You dont want detonation on stock internals.
should i change anything else? i already know i should chip the ecu. but how about head work or anything else?
no not really there are a couple of people on tr that run single cam turbos. tuning is key. Also I would think about uberdata or somthing along thoes lines for tunning.
thanx.
