Good Setup
Old Dec 8, 2004 | 04:08 PM
JDMBlackGSR's Avatar
Gators Bitches!
Default Good Setup
I am wondering if this is a good start to a N/A setup. I am not gonna do a turbo this time. I am gonna order the following:
Skunk2 Stage 2 Cams
Skunk2 Valve Springs
Skunk2 Titanium Retainers
Skunk2 Cam Gears (already on car)
Wiseco 11.5:1 Pistons
Eagle Rods
Apexi VAFC
What do you think, I have a GSR. What you think would be the approx. HP & LBS Torque.
Old Dec 8, 2004 | 04:09 PM
Gators Bitches!
Also, would I need new Injectors?
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
Old Dec 8, 2004 | 04:22 PM
qitstrn's Avatar
Can you spot me 20 cars?
190whp and you would need bigger injectors
Old Dec 8, 2004 | 05:30 PM
lead's Avatar
I'm Awesome
doesn't sound worth it..........i think you should give it a pshhhhh
EDIT: pshhhhh stands for turbocharger
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Old Dec 8, 2004 | 05:48 PM
Smart Man's Avatar
TR Balla Donor Supreme
Default Re: Good Setup
Skunk2 Stage 2 Cams
Eagle Rods
Apexi VAFC
Well, if that's what you're really going to do, you just missed a sale that would've helped you out. Racing Zone had the Stage 2 cams for around $480, and they had discounted prices on other Skunk 2 stuff, good luck with the build-up, though.
Old Dec 8, 2004 | 05:58 PM
Type LRT's Avatar
skunk 2 cams suck go with crower or crane also what about a fuel pump, regulator, intake exhaust
Single cam is the only way to go!
All motor d16a6 Civic HB 1/8 mile: 9.6
Old Dec 8, 2004 | 06:09 PM
Gators Bitches!
have all that already ... ie intake, exhaust, fuel rail, fpr
I found the cams for $500, so I am not worried about that
I dont want to turbo the car, I have had a GST and 3 TT 300zx's and all had probs
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
